NI PXI 2567
I am working on a circuit board which has relays controlled through the PXI 2567 64Ch relay driver. I would really appreciate if someone could help me create a VI to get live status of about the relay channels (either ON or OFF). This would significantly reduce my debugging time.
There's this NI Switch - Get Status function which supports such an operation. I am trying to figure out on how to use it.
(3,039 Views)
@sjadav,
Your question will probably have more successful replies if you post it on this forum instead:
http://forums.ni.com/t5/Switch-Hardware-and-Software/bd-p/320
(2,987 Views)
Thanks. I posted my question there. Hopefully, I can get a solution.
(2,910 Views)
