How to find, separate, and convert hex strings streaming through com port?
You can also store the previous values in shift registers so that you can use those values when the recieved channel does not match.
Message 31 of 39
(3,046 Views)
Is this how you would implement the shift registers?
Message 32 of 39
(3,043 Views)
@udka wrote:
Case structure accepts other types of case selector also apart from boolean.
-Case selector can be  integer, Boolean value, string, or enumerated type value.
Edit: You can even combine compare and select operations into case structure.
can you explain this part? A case structure only has a two way switch, but I need a 3 way, one for each transmitter node.
Message 33 of 39
(3,042 Views)
One way to show:
-You are talking about case selector and not strcture.
uday
Message 34 of 39
(3,027 Views)
Wire a string to the case selector input on the case structure.  You can do the same for an integer.  Unfortunately, the hex view does not exist for the string selector, so I would recommend using a lookup table.
Message 35 of 39
(3,024 Views)
No.  I would store the values that actually get written to the graph in shift registers.
Message 36 of 39
(3,019 Views)
Accepted by superomario
More like this?
Also I tried to set up the string case structure per your example but it's not looking for the strings just reports -1.
Message 37 of 39
(3,012 Views)
superomario wrote:  More like this?
Much better.
superomario wrote: Also I tried to set up the string case structure per your example but it's not looking for the strings just reports -1.
That is because you need to use the "Source Address" as your search element, not the entire data string.
Message 38 of 39
(3,003 Views)
Oh okay gotcha. Thank you for all your help. I will mark this solved.
Message 39 of 39
(2,995 Views)
