 guru13
			guru13
			02-14-2022 06:30 AM
Hi Everyone,
I want to find the between values in the array. For example:- I give 95 to 115, the values between 95 to 115 will be shown in the array indicator. After I find how many percent of value present in between (95 to 114) ; (114 to 135) ; (135 to 155); (155 to 170) ; (170 to 200) out of 200. This is a problem I am facing in my part of my coding.
I do this concept but I don't know it is right or wrong...
Anyone knows this concept please drop your comment...
And program file is also attached below.
 Defaphe
			Defaphe
			02-14-2022 07:02 AM
Finding the values is ok as you get the values you need where you need it. Maybe you will find a better (more compact) way to do it instead of X for loops.
But when your are making the percentage computing, this is wrong if I'm understanding correctly.
You need to know how many values there is in each array and divide this by the number of values in the starting array, then use array size instead of summing values.
Correct me if i've misunderstood.
02-14-2022 08:19 AM
OK, I WILL TRY THIS THANK YOU FOR YOUR COMMENT.....
 JÞB
			JÞB
			02-14-2022 08:50 AM
Use a histogram of Input Array[ ]. This will give you a count of values between limit pairs as an array<call that H[ ]. 100*H[ ] / (Size(Input Array[ ])+1) will yield an array of bin sizes as percent of population.
02-16-2022 12:01 AM
Thank you so much I will try this also...
 JÞB
			JÞB
			02-16-2022 05:11 AM
Don't forget to post back with your revised code!
03-29-2022 01:10 AM
while the code is attached below........
