How to find the time at which zero crossing point happen using zero crossing vi
Im trying your VI on a signal and it's not detecting the diachrotic notch
Message 11 of 14
(1,719 Views)
will you provide me more information about how the For loop in the block works   ?
Message 12 of 14
(1,549 Views)
Accepted by topic author laythzraiqat
For reference here is the part of the code I think you are asking about.
The subVI in the upper left is Savitsky-Golay Diff&Smooth.vi. The Greater than Zero and Implies find the zero crossings of the second derivative.  The case structure creates an output array which contains the values of the smoothed signal only at the second derivative zero crossings and NaN in all other elements. This creates the dots on the graph.
Lynn
Message 13 of 14
(1,529 Views)
I really want to thank you
ThanK you Very much
so much respect for you
Message 14 of 14
(1,517 Views)
