08-21-2010 12:10 PM
Hello!
I have built RT PC with two hard discs. I want to format the second drive, how can I do it from LV? I there any function?
Thank You all for fast reply- I know it will be fast ![]()
08-21-2010 01:29 PM
Is the System Exec function present in LV for a RT PC?
If so, use that to do a format command.
08-22-2010 02:50 AM
No, it is not present in RT function set. Even if, what command in ETS formats HDD?
Is there any other option for formatting?
08-22-2010 12:54 PM
There is a vi in the RT->utility->Format.vi
will format the HD at the specified address.
08-23-2010 09:25 AM
I am using RT v 9.0.0. There is no format.vi, only RT format target vi.
08-23-2010 09:47 AM
Sorry I assumed the second hard drive was the RT Target HD, so I suggested the Format Target VI. What RTOS you are using on the target?
08-23-2010 10:18 AM
PharLap
