Turning off automatic tool selection
Is there an option within LabVIEW that allows me to permanently turn off Automatic Tool Selection?
Message 1 of 9
(9,488 Views)
Yes, goto the Tools menu select Options... It is under the Environment page, to disable it Uncheck "Lock automatic tool selection". I am using LV 8.2.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
Message 2 of 9
(9,485 Views)
Thank you sooo much.  That has been driving me crazy!
Message 3 of 9
(9,465 Views)
thank you again... I just updated to labview 8.6 and I knew this 'feature' could be disabled. It is only very hard to find... I would expect it to be at the 'diagram preferences' tab
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
Message 4 of 9
(9,171 Views)
To access automatic tool selection, you can use the hotkey as well.  Hold down the left SHIFT key while right-clicking.
Best of luck programming,
Kevin S.
Message 5 of 9
(9,129 Views)
Unfortunately, this suggestion does not "permanently disable" automatic tool selection.  It just enables toggling off with the TAB key and on with the Shift-TAB key.
I would very much like to be able to "permanent disable" this feature, so that it does not come on and give unexpected selections, if I accidentally toggle it on.
I'm guessing there is not a way to do this but if there is, please let me know.  I find this feature distracting.
Message 6 of 9
(8,869 Views)
See the reply by Andrew Alford above in this thread.
Tools>>Options>>Environment>>Lock Automatic Tool Selection (deselect)
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
Message 7 of 9
(8,860 Views)
Yes, my comment was in response to this "solution".  I tested the solution.  It does not permanently disable; it only allows toggling.
Message 8 of 9
(8,834 Views)
You are correct. I never noticed this before as I am a "Tabber" - I use the Tab key to rotate through the tools palette. Which always turns off Auto Tool Select.
CLA
Message 9 of 9
(8,772 Views)
