How to generate Strain Gage Calibration Information like MAX
Hi All,
I am making some modifications to the strain example (Cont Acq Strain Samples (with Calibration).vi) to use with my PXIe-4330 Bridge cards.  I am wondering if I could generate strain gage calibration information after offset nulling and shunt calibration similar to what MAX does when you set up a DAQmx task?
Thank you,
Lynniz
(2,930 Views)
Hi Lynniz-
     Here is an example program that shows you how to pull calibration data from DAQmx in LabVIEW.  I hope this helps!
Gary P.
(2,900 Views)
Thanks Gary, the example was really helpful.  I have another question.  For my application, I am doing bridge balance and shunt calibration on my channels.  If I want to apply the same calibration data back to some of the channels within a new task, do I just apply the Bridge:Shunt Cal:Gain Adjustment and Bridge: Initial Bridge Voltage (DAQmx Channel Property) from the previous calibration to these new channels?  Anything else I need to do?  Please let me know if my questions are not clear.
Thanks in advance
Lynniz
(2,873 Views)
Lynniz-
     You have the right concept, but the property that you want to use is AI.ChannelCal.Poly.ForwardCoeff.  You input an array of coefficients which you can get from the above referenced example.
     I hope this helps.  Have a great day!
Gary P.
(2,853 Views)
