How to generate a derivative of the extracted line profile
I created a line profile and mapped it on a graph. Now I have to derive this graph. How do I do that best?
thanks
Message 1 of 8
(1,974 Views)
i want to get a line profile. But for that I have to enter the coordinates of the image. How and in what form can I enter the coordinates there? Can I get a simple example from you on how to use this module?
thank you
Message 2 of 8
(1,968 Views)
it's too hard ???
Message 3 of 8
(1,933 Views)
Hi Panther,
have you tried to use the derivative function?
Message 4 of 8
(1,970 Views)
Yes, but i have no idea how can i connect my Graph with the derivative function.
can you give me some help?
Message 5 of 8
(1,966 Views)
Hi Panther,
use UnbundleByName to get the line data...
Did you look at the context help when moving the mouse over those wires?
Message 6 of 8
(1,957 Views)
ok thank you for this tip UnbundleByName. I used it and connected it. I get three parameters x0 dx and pixelsline. "x0" is always 1, "dx" is always 0 and pixelsline is variable. I connected pixelsline with the derivative.
and i get a second graph. now is my problem. That the first graph on the right shows a pixel value of 200, but the derived graph on the left shows a value of 30. Do you know why?
thank You
Message 7 of 8
(1,930 Views)
You calculated the first derivative of that line. Do you know what that means?
The biggest chance between two adjoining data-points seems to about 30, so that's the max value on the derivative graph.
Regards, Jens
Kudos are welcome...
Message 8 of 8
(1,924 Views)
