How to generate a string
Is there a way to create an empty string of arbitary length?
What I mean is
I have an integer as input
This integer tells the length of the string
An empty string (containing only 00h) with that length is the output
(2,526 Views)
Accepted by Kirillenseer
Create a U8 array (using Initialize Array with value 0) and feed it into Byte Array to String. You can also auto-index an empty string out of a for loop and wire the resulting array into a Concatenate function, which will convert it to a single string.
___________________
Try to take over the world!
(2,520 Views)
