How to generate a triangle waveforma array for a particular duration?
I am generating a triangular waveform from a starting potential of 'x' to a switching potential of 'y'. I want to set a hold period after generating the array for a specific time.
For example, after I have generated a triangular signal containing 1000 points, I want to hold the waveform for some duration before applying the potential again. In the attached vi, CreateWaveform.vi, after i get a triangular pattern, I want to insert a hold at the starting/negative potential for a time period determined by the frequency that i set.
(2,778 Views)
what is meant by holding the waveform for some duration? is it a set of new value that needs to be appended to the traigle waveform?
Regards
Guru (CLA)
(2,758 Views)
