Open Excel read and write problem
I am trying to deterimine what is causing excel files to open up as "Read Only" using Labview, when I excplicitly state to open as "ReadWrite"
It seems to work well in the development environment, but not so well on some PCs in the application environment.
(2,740 Views)
Are you using a template file? Is the file marked as "read only"?
Do you or the application has proper admin rights in the PC where it used?
Guru
Regards
Guru (CLA)
(2,710 Views)
