How to generate color box on block diagram?
I found the snippet below in an example, but I can't recreate the color box on the block diagram using LV 8.6.  I can generate a color box from the front panel and then change it to a constant on the block diagram, but shouldn't I be able to do insert a color box directly from one of the pallets on the block diagram?
Thanks in advance.
(3,609 Views)
The Color box constant is in the "Graphics & Sound -> Picture Functions" pallette.
(3,606 Views)
Right click the block diagram
then click the Search button in the top right corner
then type color constant 🙂
(3,604 Views)
Accepted by VI_Joe
and more... ...
(3,595 Views)
