How to generate digital square wave with PXI-6251?
Hi gents,
I am trying to generate two square waveforms and my only requirement is to set frequency up to 1 kHz. Nothing more. But I tried lot of DAQmx concepts and I don't understand the principle of different forms here. If I should use some digital waveform and send it to the DAQmx write function, how to use sample clock (if even use). Basicaly I tried things with intuition, but I miss here the principles. Can you please guide me to some point or architecture I can use?
Thank you in advance a have a nice day!
Martin
Message 1 of 10
(4,756 Views)
Hi Martin,
create a counter output task to generate a pulse trail. You can set it's frequency quite easily then…
(There also are example VIs in the example finder that explain such a DAQmx task.)
Message 2 of 10
(4,755 Views)
But how I can create two signals with different phase then? There is no option for standard DIO without using counter?
Message 3 of 10
(4,743 Views)
Hi Martin,
I love it when the OP puts all requirements on the table right in the first post… (Sarcasm! :))
Well, there are surely example VIs that explain the use of "simple" DO channels. Did you examine them?
Yes, you could output digital waveforms too…
Btw. why do you think two counters will be "in phase"?
Message 4 of 10
(4,721 Views)
Hi GerdW,
thank you for putting more light into this problem so far. I was not able find these examples before. *Blind*....
Anyway, I am now finding out, that I do not know how to properly set the clock source. I have got this error when using refClock and if I use Onboard clock, it returns error too...
I am using PXI-6251
Martin
Message 5 of 10
(4,689 Views)
Hi Martin,
do you really need to start with a sample rate of 10MHz?
As the error message clearly says you are beyond the hardware limits here.
For learning purposes you might start with sample rates of 1kHz!
Message 6 of 10
(4,684 Views)
Yes, you are right, but then I would get this error...
Martin
Message 7 of 10
(4,681 Views)
Hi Martin,
does the example VI use a "10MHzRefClock"?
Don't wire the clock input for a test (or try a different clock)…
Message 8 of 10
(4,679 Views)
Well, I am force to have there source. First, it is done in this example and second, it does not work without it.
Message 9 of 10
(4,676 Views)
Accepted by topic author mzema
So for this case with PXI-6251 there are two options for digital output with internal clock I tried:
  • to use 100 kHz timebase with possibility to dived this timebase by 1-16 ratio
  • to use counter internal clock as recommended above - with Lines PXI1Slot2/port0/line0:1 and data write array (U8 data) for creating reqired signal pattern (0 - low state on both lines; 1 - high state on line0; 2 - high state on line 1; 3 - high state on both lines 0,1)
Martin
Message 10 of 10
(4,654 Views)
