How to generate random numbers from 1 to 5
-1110340081
(3,188 Views)
Random integers 1,2,3,4,5 or random floating point numbers 1...5?
What have you tried so far? Where did you get stuck?
(3,185 Views)
Accepted by fewfew
thank you i have finished
(3,176 Views)
(You should not mark a post as solution unless it actually contains a solution to the original problem)
Do you want to share your code? Did you test to make sure that all numbers equally probable?
(3,164 Views)
