How to generate the simplest toggle output in the while loop?
I want to generate the toggle output true and false within the while loop. I can do the output but it is very complicated I am sure there should be a very simple way that we can generate the toggle output.
Saw
(2,698 Views)
I would suggest you use a shift register and not function
(2,698 Views)
example attached
(2,698 Views)
