Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to generate the simplest toggle output in the while loop?
Alexander J.
Member
04-25-2003
05:01 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to generate the toggle output true and false within the while loop. I can do the output but it is very complicated I am sure there should be a very simple way that we can generate the toggle output.
Saw
0
Kudos
Message
1
of 3
(2,851 Views)
Reply
Re: How to generate the simplest toggle output in the while loop?
paul_s
Member
04-25-2003
05:45 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I would suggest you use a shift register and not function
0
Kudos
Message
2
of 3
(2,851 Views)
Reply
paul_s
Member
04-25-2003
05:51 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
example attached
toggle.vi 26 KB
0
Kudos
Message
3
of 3
(2,851 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
