How to get 3D coordinates of reflective markers using two cameras?
I am very new to LabVIEW (in fact to any coding at all) and helping my adviser to get the 3D coordinates of a few reflective markers using two cameras. I am able to read the marker coordinates (x, y) from two cameras simultaneously by processing the data in real-time using codes generated from vision assistant. However, we want to get the depth position by triangulating the markers. I have seen stereo vision doing something similar to this, but I think the stereo vision may not work with our calibration frame (markers) and we don’t need the whole depth image, but only the maker’s z coordinates. I also want to use Region of Interest to mask out other regions that are creating reflections. However, I am not sure if triangulation would work if we select region of interest (as the origin of the camera coordinates would change after selecting ROI). I saw this link http://kwon3d.com/theory/dlt/dlt.html#3d where they used DLT (direct linear transformation) method, but it is too much to code from the beginning. Is there a subVI in LabVIEW or some sort of prewritten code that can be customized? Can anyone please give me some advice on how to solve this problem?
Message 1 of 8
(3,456 Views)
Well in theory, if you know exactly where the cameras are pointed, how far apart they are, and how far the reflector images are above or below the horizon and to the right or left of center line, a little simple math should give you the answer. Concerning the ROI I would think all you needed to know was where the ROI was relative to horizon and centerline. You could then calculate an absolute position from there, which would also give you the angles you would need.
Unfortunately, I don't know of any readily availble code. But I'm sure there is some! With the emphasis on FIRST robotics, I got to believe that judging distances in 3D space is something for which there is a lot of code.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(3,422 Views)
From the FIRST Robotic community page
https://decibel.ni.com/content/docs/DOC-20173
https://decibel.ni.com/content/docs/DOC-26318
These are all for high school students
Omar
Message 3 of 8
(3,419 Views)
Hi Mike,
Thank you for your reply. Can you please let me know whether I should use the shortest distance between the two cameras? and also please explain how do I calculate "how far the reflector images are above or below the horizon and to the right or left of center line"?
Message 4 of 8
(3,337 Views)
Hi Omar,
Thank you for posting the links of tutorials for image processing.
Message 5 of 8
(3,333 Views)
Distance between centers of the lens'. That's what the reference for the image is.
Mike...
LabVIEW Champion
Message 6 of 8
(3,327 Views)
Thank you for the reply. Can you please explain what is meant by above or below the horizon and to the right or left of center line.
Message 7 of 8
(3,276 Views)
ok, horizon first: If the camera is level (0 deg of pitch up or down), you can draw a line horizontally through the middle of the image and everything above that line will be above the camera, everything below the line will be below the camera, and things right on the line will be on the same level as the camera.
Left and right of center is the same concept except rotated 90 deg, so the camera need to me vertical. Another way of putting it is if the camera was an airplane it would have 0 deg of roll.
Finally, one other point I forgot was the camera need to be pointing straight ahead relative to the vehicle it is mounted on (i.e. 0 deg of yaw).
Mike...
LabVIEW Champion
Message 8 of 8
(3,250 Views)
