How to get Date/Time in Numerical form?
Hey Dev,
as per ur reference i ve trid to see the examples but i dont find the proper thing i want, the 1st of the examples Read datalog file example doesnt run and i dont no how 2 assign a file to it and which file to assign to it, coz it is also not taking the file .lvm which is already a file of labview, so i am not sure whether how to work with them and another example i ve find but it is not taking the continuos date or time coz i cant write the Date and time in numerical format in the storage files, if that is possible it also can solve my this problems.
Nishant
Message 11 of 39
(1,619 Views)
Hi Nishanth,
First write data using write datalog file VI (From examples )
Then read data from it using read datalog file VI
This read Vi is customized to read data that is logged using the write VI
Try using the same logic to achieve the type of logging you want
Regards
Message 12 of 39
(1,621 Views)
Hi Nishant,
Converting a date and/or time string (or timestamp) to a numerical value is no problem.
You forgot to attach your VI in reply 9. Can you post your VI and i will look at it.
Message 13 of 39
(1,612 Views)
Hey KC,
                Here i am sending you the file which i am coding right now, i have reach upto certain mark, but not at the concluding results, currently i am getting the hour of the time and date of the whole date format, but i want it in whole format so i am finding the format, just see it u will udstand wat i m trying to say, and if ucan suggetst me any other method it is also regarded.
      Hey Dev,
                    That example isnt helping me coz i want to store data in the excel file so that user can see it and i also want that date and time should be displayed on the X-axis of the graph, instead of numerical random time.
Nishant
Message 14 of 39
(1,602 Views)
Where's the VI ?  Smiley Sad
Message 15 of 39
(1,600 Views)
Sorry Man,Smiley Mad
I m really sorrySmiley Happy, i ve send it in hurry & forgot  to send the vi.
Here it is now atlast.
Sorry & Thanks,
Nishant
Message 16 of 39
(1,597 Views)
Still don't understand what you want. In your VI you are trying to generate date&time an add this to a file Smiley Surprised
Can you show me in a spreadsheet (textfile) what you want.
Message 17 of 39
(1,590 Views)
Hi Nishanth,
Modified your VI,
is this what you are looking for?
regards
Dev
Message 18 of 39
(1,589 Views)
Hi Nishant,
in the attached VI,
since you are doing only one date/ Time query along with each 2D array data set in each iteration, your excel file will contain only one stamp for each chunk of 2d array data.
regards
Dev
Message 19 of 39
(1,589 Views)
Thanks Dev,
Ya its a really nice solution, and that is want i want. it will solve my problem for sure. thank you very much and thanks to the KC for guiding me what to do, i will send you my vi, after getting perfect solution with the data.
Smiley Happy
Smiley Happy
Nishant
Message 20 of 39
(1,581 Views)
