12-12-2005 01:01 AM
Hey Dev,
as per ur reference i ve trid to see the examples but i dont find the proper thing i want, the 1st of the examples Read datalog file example doesnt run and i dont no how 2 assign a file to it and which file to assign to it, coz it is also not taking the file .lvm which is already a file of labview, so i am not sure whether how to work with them and another example i ve find but it is not taking the continuos date or time coz i cant write the Date and time in numerical format in the storage files, if that is possible it also can solve my this problems.
Nishant
12-12-2005 01:10 AM
12-12-2005 01:31 AM
Hi Nishant,
Converting a date and/or time string (or timestamp) to a numerical value is no problem.
You forgot to attach your VI in reply 9. Can you post your VI and i will look at it.
12-12-2005 03:11 AM
Hey KC,
Here i am sending you the file which i am coding right now, i have reach upto certain mark, but not at the concluding results, currently i am getting the hour of the time and date of the whole date format, but i want it in whole format so i am finding the format, just see it u will udstand wat i m trying to say, and if ucan suggetst me any other method it is also regarded.
Hey Dev,
That example isnt helping me coz i want to store data in the excel file so that user can see it and i also want that date and time should be displayed on the X-axis of the graph, instead of numerical random time.
Nishant
12-12-2005 03:13 AM
12-12-2005 03:43 AM
12-12-2005 03:55 AM
Still don't understand what you want. In your VI you are trying to generate date&time an add this to a file ![]()
Can you show me in a spreadsheet (textfile) what you want.
12-12-2005 03:57 AM
12-12-2005 03:59 AM
Hi Nishant,
in the attached VI,
since you are doing only one date/ Time query along with each 2D array data set in each iteration, your excel file will contain only one stamp for each chunk of 2d array data.
regards
Dev
12-12-2005 04:28 AM
Thanks Dev,
Ya its a really nice solution, and that is want i want. it will solve my problem for sure. thank you very much and thanks to the KC for guiding me what to do, i will send you my vi, after getting perfect solution with the data.
Nishant
