How to get a boolean control to NOT queue up button click when it is invisible/disabled
Sorry, Dennis.  I've attached just the VI.
I am using 'value change' event, yet still see the problem.
Is this because I'm using an old LV (8.2)?
Also, I'll correct my profile (i.e, no longer an NI employee) as soon as I can figure out how to.  Wasn't obvious from a quick attempt.
Message 11 of 13
(533 Views)
Not a LV8.2 issue, just a fact of life when putting time consuming operations into your Event structure.  Examples of the two solutions I described earlier.  First one uses the P/C template to handle the events in realtime, second uses the busy cursor to prevent clicks.
Message 12 of 13
(520 Views)
Here is the 8.0 version of my vi
Tim
GHSP
Message 13 of 13
(511 Views)
