How to get binary values from EPICS?
I am logging process variable from EPICS and everything works correctly, except the binary values I want to log. They are simply 0 all the time and don't change when they should. I'm assuming there's some kind of data type issue I'm not understanding, but I can't figure out what it is. In my db file I set the PVs as bi or bo, and in EPICS I've tried making them integers and booleans converted to doubles. Any suggestions?
(3,262 Views)
Hi andersd,
Are you using an EPICS client I/O server in DSC?
Jeremy_B
(3,242 Views)
Yes, I am using an EPICS I/O server in DSC.
(3,215 Views)
How are you confirming what the actual values should be?  What kind of data are you expecting?  Are these just boolean switches?
Jeremy_B
(3,198 Views)
