Subtracting a time stamp from another time stamp...
hi...
take a look at the attached VI.
should give me only 0,006 sec or 0,007 sec
but gives me 1hr 0min 0,006 sec...how?
(3,204 Views)
If u observe the output of subtraction function, it will show '0.0069999' or 6-7 milliseconds as the difference ( which is what you expect)
But then, you are converting that into timestamp which is the time-zone-independent number of seconds that have elapsed since 12:00 a.m., Friday, January 1, 1904, Universal Time.
Hence the incorrect result
(3,200 Views)
Hi Dev...
thanks a lot...
i did realize that the difference is correct in terms of float.
but i was unaware that the time stamp is time-zone-independant.
i tried by changing the timezone...it worked perfect...
now it is clear to me... thanks...
(3,171 Views)
Interestingly enough, on my system I get something completely different:
Amusing.
Message Edited by smercurio_fc on 08-06-2008 10:58 AM
(3,146 Views)
I think you sent a negative number to the timestamp indicator? Some combination of the difference, daylight savings time and time zones.
Lynn
(3,135 Views)
If you want to see the relative time, you need to create a DBL indicator after the substraction, right click it, select Display Format... and change the format to relative time.
___________________
Try to take over the world!
(3,130 Views)
To be honest, I didn't investigate it. I was just curious to see what would happen, and I just left it at that.
(3,114 Views)
