How to get bothAnalog 2D DBL and Analog 1D wfm from DAQmx read.vi
Hi
I am using Labview2010 and NIUSB6009 for aquairing data. I need to have both Analog1D waveform and
Analog 2D DBl from DAQmx Read.vi. i am doing continus sampling.
any idea how to get both types from DAQmx Read.vi?
thanks
(2,804 Views)
Accepted by topic author qazi ahmad
If you are acquiring the data from one channel at a time then you will probably get 1D array of waveform. If you want to acquire the data from several channels at a time then you should get 2D array contains all information from channels.
If I am right, You can not get both the data types(1D and 2D) from from DAQmx read function. I haven't heard this. This is all what I can expect.
(2,791 Views)
Your question does not make much sense. Whu do you think you need both? You can easily acquire multi-channle data as a 1D waveform and convert to a 2D DBL if you want. Just use the Get Waveform Components inside a for loop.
(2,787 Views)
I got your point shjukheter. thanks
(2,778 Views)
Still don't understand what you are doing. Be aware that with the 2D dbl, you lose the timing information.
(2,774 Views)
