Strange current VI`s path returned in standalone application
I know that there is a difference in the path returned when using the "Current VIs path" in the development environment and in a standalone application, but this is not what I had expected: This is the path returned from the Current VIs path in the standalone application:
C:\LabView-programmer\RADHAZ-programmer\RADHAZ\builds\rad.exe\RADHAZ-programmer\RADHAZ\rad.vi. Why is this the correct path to the VI?
If I strip this path once, and build a new path with the name of my dynamically called VI  I get: C:\LabView-programmer\RADHAZ-programmer\RADHAZ\builds\rad.exe\RADHAZ-programmer\RADHAZ\instr.vi. It starts from this path, but It won`t load some text-files located at C:\LabView-programmer\RADHAZ-programmer\RADHAZ\builds\kal-data without making changes to the instr.vi.
I tried to used the App.Dir property to find the correct top level directory, and it returns C:\LabView-programmer\RADHAZ-programmer\RADHAZ\builds as expected. But this is not the path that the dynamically called VI need.
Any suggestions is appreciated..
I searched for a detailed tutorial for setting up the build specification, but didn`t find any that helped much.
Gunnar
(2,612 Views)
Accepted by topic author Gunnar_Kulbotten
HI Gunnar,
have you tried the last point of the Advanced AppBuild settings as described in the help?
(2,596 Views)
(2,511 Views)
Hi
For a little more explanation take a look at this KB
Basically when you create an .exe file you get an extra folder.
Reagards
Espen
(2,492 Views)
I used GerdW`s advice (advanced settings"Use LabVIEW 8.x file layout"), problem solved!
Gunnar
(2,476 Views)
