How to get class variable name text
Hello. I am wondering if there is a way to get the name of lvclass control objects similar to how you would get the text label of other objects by reference? Property nodes don't seem to help much. You can see in the image, I would like to get the text name of the lvclass variable _string_selection.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
(2,597 Views)
Accepted by Jay14159265
It's a bit of a journey, but you can get there....  There might be an easier way, but this does it.
Just replace the object terminal with an instance of the actual class.  VI in 2018 attached
(2,572 Views)
Thanks for the help! you are not kidding about the journey.
(2,558 Views)
