How to get data through GPIB?
I am new on Labview.
How can I get the temp data vs time from a cooling/heating instrument through GPIB?
I use LabVIEW 2017.
Thanks!
Message 1 of 9
(6,660 Views)
Have you downloaded and installed the instrument driver?  There might be an example program included with the drivers to help you get started.
aputman
Message 2 of 9
(6,650 Views)
Which instrument driver?
Thanks.
Message 3 of 9
(6,641 Views)
You'll need to check with the manufacturer of the instrument.
You can check if it's available in the NI Instrument Driver Finder.  Look in the Help menu.
aputman
Message 4 of 9
(6,636 Views)
I think the NI found the instrument GPIB, see attached.
Message 5 of 9
(6,621 Views)
Looks like this is the driver you want to get.
Message 6 of 9
(6,616 Views)
I think the GPIB is communicating.
Message 7 of 9
(6,613 Views)
Are you new to instrument control also?  Answering this question would give us an idea of what kind of help you need.
Bill
CLD
(Mid-Level minion.)
Message 8 of 9
(6,571 Views)
yes, i am new at any Labview things. Here is my update:
i established communication between the thermal instrument and Labview NI-488.2 driver through GPIB, see attached.
My goal is to download the thermal data file but couldn't find the command syntax, the closet one I got is the :ibrdfile 0013 (the filename) but received error message. I am working with the thermal instrument vendor for the location of the file.
Thanks.
Here is the result communication with the instrument:..............................
Interactive Control
Copyright 2007 National Instruments Corporation
All rights reserved.
Type 'help' for help or 'q' to quit.
 ud0: help
 ud0: ibdev
    enter board index: 0
    enter primary address: 9
    enter secondary address: 0
    enter timeout: 13
    enter 'EOI on last byte' flag: 1
    enter end-of-string mode/byte: 0
ud1: ibclr
[0100]   ( cmpl )
ud1: ibwrt
    enter string: "*IDN?"
[0100]   ( cmpl )
count:  5
ud1: ibrd
    enter byte count: 29
[0100]   ( cmpl )
count:  29
54  45  4d  50  54  52  4f  4e          T E M P T R O N
49  43  2c  54  50  30  34  33          I C , T P 0 4 3
30  30  41  2c  34  30  30  30          0 0 A , 4 0 0 0
2c  56  65  72  73                      , V e r s
ud1: ibloc
[0100]   ( cmpl )
ud1: ibrdf 0013
[8100]   ( err cmpl )
error: EFSO
count:  -536215450
Message 9 of 9
(6,552 Views)
