temperature controling
Hi  I wana control my temperature in a system so to an optional curve(sinusoidal, cosine wane, etc), how can I do that,does It needs programming? I have some primitive data like my momentary temperature, how can I match my temperature with my desired curve that gives me an acceptable precision.
I work with ni-usb 6009
(4,075 Views)
Hello hsadegh,
Yes, you will need to write a program for your application. How are you controlling the temperature? Do you output a voltage that controls a heater/cooler? Usually temperature control devices like a TEC require a current draw that I'm not sure the USB-6009 is capable of.
Assuming you do have a way to control the temperature through either a voltage or current, it will probably not be enough to simply send a sine wave of voltage and hope to get a sine wave in temperature. Most people use a PID loop to get as little overshoot as possible, but you may be able to purposely create an overshoot by raising the D parameter. Then you can change the rate of your update loop to adjust the frequency of the ringing a little bit. I don't know if this will be as precise as you want though, but it will probably be an exercise in trial and error.
(4,059 Views)
hello  gregoryj
I almost understand what you said, I used the voltage(LM35 sensor) to check my realtime temperature, I used PID control to regulate my temperature but I don`t know how to define and control temperature in a sine wave like diagram.
(3,999 Views)
How do you communicate with your temperature chamber?  Is it through GPIB? Ethernet/LXI? Serial? other???  What chamber are you using for temperature?  What instrument(s) are you using to read back the temperature from the chamber and how are they being controlled?
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,986 Views)
