How to get only seconds from the time block function?
How many times did you want elapsed time to run?- Just the Once?
Stick it in the acquisition loop!
Message 11 of 17
(1,376 Views)
Where do I have to wire the iteration of for loop to?
Message 12 of 17
(1,355 Views)
It would be appreciated if you show me as an image or file. I want it to start from 0, 1, 2,... till I stop the run button
Message 13 of 17
(1,346 Views)
what sense has the wait funktion in the second for loop?
I think you you have to another wait function that influence the time you´re want tool.
--> I work for KUDOS <--
Message 14 of 17
(1,315 Views)
The reason why I have a waiting function in the second for loop is to make the user able to change the data saving frequency appearing in the front panel. Unfortunately it isn't correct. The data saving frequency in the text file isn't corresponding to the the delay time in the code. It should be starting from 0,1,2,3,4... if the user enters 1000ms. or 0, 0.5, 1, 1.5,...  if the user enters 500ms.
Do you have any ideas?
Message 15 of 17
(1,302 Views)
The wait function in the for loop causes that for every element in the loop you have to wait the defined time.
For example:
The array has five Elements and you want set the Time on 100 ms the Data would be saved every 500 ms after the for loop ends.
Greez
Message 16 of 17
(1,278 Views)
is your Problem already resolved?
Greez
Message 17 of 17
(1,243 Views)
