How to get "selected text"? from a string
If I highlight text in a text string, I would like to be able to copy it to the clipboard.
I have already created an event that utilizes the Application reference to "write to clipboard"  now I need to give it the selected text.
How do I do that?
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(4,715 Views)
Control-C will copy just your selected text to the clipboard but right-clicking on a control and selecting Copy Data will put the text of the whole control into the clipboard.
Albert
(4,706 Views)
Accepted by eximo
Here is a way to do it.
Ben64
(4,700 Views)
Albert
Copy data will put an image of the data on the clipboard, but not the txt, so if your txt exceeds the space of the window you are out of luck
-Regards
eximo
Neuronetrix
(4,687 Views)
thanks ben64;
sushu;
Certified LabVIEW Developer (CLD);
(4,565 Views)
@sushu wrote:
thanks ben64;
Best way to thanks is to give kudos 😉
Ben64
(4,557 Views)
Yes , Cat Happy
sushu;
(4,551 Views)
