How to get rid of the reference lines on the front panel
I forgot how I created a couple of horizontal and vertical reference lines on the front panel. It looks like the origin lines on the front panel. When I move my program to another monitor with different resolution, all the layout is messed up because of the reference lines can not change with the resolution. Did anybody meet this before? How to get rid of them?
Attached are the 2 creen shot of front panels.
Thanks in advanced.
(3,773 Views)
You will have to click on the top menu and choose options see below
when you do this window will pop up and you scroll down until you get to the front panel options. See below
Tim
GHSP
(3,750 Views)
Thanks for your reply soon.
I tried to shut down the grid and turned off the gird alignment as you told me. However, the two pairs of reference lines are still there ( see attached image). front panel3.png
(3,741 Views)
Can you attach your code?
Tim
GHSP
(3,738 Views)
Are your "reference" lines decorations?  Can you select them?  If so, select then delete.
Lynn
(3,724 Views)
Accepted by BlueBill
Aha, I figured out. I accidently selected the "Scale Object with Pane" in the shortcut menu of one button on the tab. That is where the reference lines come from.
Thanks for all your guys help and hints.
(3,717 Views)
