10-22-2014 10:17 AM
Hello everyone,
Problem Description: I am using DAQmx Physical Channel as control. I have selected few channels from browse option. Now i want to get number of selected channels from list.
I checked in Measurement I/O-> NI-DAQmx. But couldn't find
Is there any way?
Solved! Go to Solution.
10-22-2014 10:30 AM
in 1k Words
10-22-2014 10:52 AM
Here your control is DAQmx Task. But my control is DAQmx Physical Channels.
In DAQmx Task "user" don't have option to select channels, Whereas in DAQmx Physical Channel "user" has option to select which ever channel he/she want. ( PXI1slot4/ai0)
When I checked "DAQmx Physical Channels" there is no property call Numchans. Is there any other way to do?
10-22-2014 11:25 AM
I guess the easiest option is to unflatten into an array first:
10-22-2014 11:40 AM
Awesome!!! Clark ![]()
