How to get time in UTC format?
Hi all,
LV 8.6.1 + Windows XP SP2
During last weekend my code went to error because current time was changed to summer time. This question might be very easy but I can't find a solution. How I can get current time in UTC format? E.g if local time is 14:30 (+2h, winter time) my code show UTC-time 12:30. When I change current day after May last sunday i get same result. Because summer time is 14:30(+3h, summer time) time should be 11:30. I also want convert time to timestamp control...
BR, Jim
Message 1 of 11
(19,509 Views)
Accepted by SnowForest
Message 2 of 11
(19,503 Views)
Exactly how does that GetUTCOffset.VI work?
Judging by the poor rating it is getting, noone else knows either..
Please help.
Message 3 of 11
(19,141 Views)
Actually that answer just gave a hint to me. After that I made my own UTC-time VI. Maybe this VI helps you...
BR, Jim
Message 4 of 11
(19,122 Views)
I know this thread is rather old, but this might help with the original question of displaying a time in UTC.
You can make a time stamp indicator show UTC by editing its format string. In the editor select advanced editing mode. You'll see the format as %<something>T (something is the date/time format specifier which may spread over more than one line). Change the format to %^<something>T and the time will show in UTC.
Rod.
Message 5 of 11
(19,106 Views)
can i get the format in labview 8.0
Message 6 of 11
(18,881 Views)
It is here:
Message 7 of 11
(18,858 Views)
Rod.
Anyone have any idea why this info was removed from the Time Format Dialog after LV8.5.1 (see below)?
Does this imply that the capability might go away in the future?
It used to be right there, but in LV 8.6 and LV 2009 the selection for "Universal Time Container" is gone.
LV 8.5.1:
LV2009:
Message 8 of 11
(18,753 Views)
Why does nobody use it like this?
Isn't it available in the previous versions of LV?
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that... 🙂
Chart zoom with "Mouse Over" effect
Message 9 of 11
(18,743 Views)
In my case I was referring to the display format for a timestamp indicator or constant (as opposed to formatting a timestamp wire into a string).
Message 10 of 11
(18,737 Views)
