How to get value of public static field of a .NET class
Hi All,
    Here, I have to retrieve the value of public static field of a .NET class, but I can not find any language construct of LabVIEW supporting it.
    The public static field I try to access is :
https://docs.microsoft.com/en-us/dotnet/api/system.windows.automation.windowpattern.pattern?view=net...
   Is there any way to access the public static field without wrapping it by C# into another class?
Thanks for all your help
Godel
(1,415 Views)
Accepted by topic author godel
I assume you tried using a Property node, selecting the WindowPattern class when browsing for the .NET class to use. Then selecting the static field from the list. Like so:
(1,412 Views)
Hi tyk007,
    Thanks for your kind help. I have accessed it through property node.
Godel
(1,399 Views)
