How to get y value by y value in xy graph
It is beginner Labview user.I want to determine an x value by entering the correspondent y value in an xy graph but unfortunately i havent achived yet. i hope one can help here, thanks.
Emin Ekşi
(3,255 Views)
The cursor will show you the values associated with a point on a graph. Pop up on the plot area of the graph and check Visible Items >> Cursor Legend. Use the help files to get more information.
If you want to get the data programmatically you can use the threshold array function.
Lynn
(3,253 Views)
One caveat with Threshold Array- data in the array must be sorted in non-descending order.
(3,250 Views)
yes, now it works. thanks a lot!
(3,244 Views)
