How to graph time vs. voltage from the analog input from NI 9215
I using the NI 9215 analog module with a FPGA and cRIO. I am transfereing the input data through a DMA FIFO to the RT host code on the RIO. I would like to create a graph with the time vs. voltage. From this graph I would like to calculate the frequency. I have not been able to solve this on my own.
Please let me know if you have any input as to solve this.
Thank you,
Lisa
(3,892 Views)
hi Lhicks,
  Please check the examples...go to example finder and type type your requirement like analog input..
Thanks and regards,
srikrishnaNF
Srikrishna
(3,869 Views)
I have checked all the examples and I am unable to find one for the NI 9215 module.
(3,861 Views)
Hi Lisa,
The 9215 is a fairly standard analog input module so the example Analog Input - cRIO.lvproj might help you. It's located in Hardware Input and Ouput >> CompactRIO >> Basic IO. If it's the plotting of data that's giving you trouble check out the Graphs and Charts folder in the example finder under Fundamentals. The Waveforrm Graph.vi is a good starting point.
Concerning calculations, you'll want to perform those with the data itself, not from the graph. There are analysis VIs that will help you take a spectrum of your data. One that I've used before as a starting point can be found in Analyzing and Processing Signals >> FFT and Frequency Analysis >> Simple Spectrum Analyzer(sim).vi.
I hope this helps you get started!
Verne D. // Software R&D // National Instruments
(3,854 Views)
I am have trouble with graphing the power spectrum, in a way that is useful. i.e. Frequency vs. Amplitude. I have been unsuccessful in finding a VI that can input a type double, continuous input, and calculate the power spectrum and output that to a graph with Freq. and Amp.
(3,836 Views)
FFT Power Spectrum, Power Spectrum, the Express VI Spectral Measurements.
(3,823 Views)
