Intiallization of PID vi controller block in LabVIEW 2009 with cRIO 9014
Hi there, i'm using LabVIEW 2009 with cRIO 9014 to control external DC motor as a part of actuator.
The program which i made for this task is made with PID vi control block .
My problem is that i want to intiallize the parameters of the PID vi controller block whenever the steady state error (setpoint - process variable) is changing orientaion,or in other words when it's changing from plus to minus and vice versa.
Is there any function in LabVIEW which executes only once? i wanted to implement one-time intialization of the PID controller block only in the case that the steady state error change it's orientation...
Thanks for any help!
Yaron
(2,529 Views)
Search the palette for "First Call?"
(2,525 Views)
Excatly what i need, super !
thanks !
(2,511 Views)
