How to handle TPC Screen Resolution
How do I setup the correct screen aspect ratio / Screen size for a TPC 2215 if my application is created on a desktop computer with two monitors neither of which are close to the TPC 2215 screen size?
When you create a Touch Panel Project and select the TPC 2215 Target it does not seem to limit the front panel size.
How do I ensure my controls do not extend beyond teh bounds of teh TPC screen?
Thanks In Advance
Tim C.
1:30 Seconds ARRRGHHH!!!! I want my popcorn NOW! Isn't there anything faster than a microwave!
(3,308 Views)
Hi Tim,
When you have your VI open, if you go to File>>VI Properties>>Window Size, you can set a minimum window size in pixels.  Set this to your TPC resolution, and then shrink the front panel window until it hits these minimum bounds.  Then you should be good to go!
David R
Systems Engineer
(3,242 Views)
