How to hide command prompt window when using system exec
Hello, I'm using the system exec VI to do some file transfers for a LabVIEW application.  I'm worried that the black command prompt window with white scrolling text that pops up when system exec is called might frighten the non-tech savy users of this LabVIEW application.  Is there a way to hide the command prompt window?
(6,798 Views)
Accepted by topic author Mike Mogenson
Wire a TRUE to the Run Minimized input.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(6,796 Views)
Wire the Run Minimized window to True.  I tested this by asking for a directory (saving the output in a LabVIEW indicator).  By "default", the "black screen" flashed briefly, but when run minimized, I never noticed it.
(6,794 Views)
Thanks, that was an incredibly easy solution that I missed.
(6,788 Views)
