wire usb-6009 for mux
I need to use a usb-6009 (or the like) daq to wire it for 1 to 4 mux, comports (rs232 wiring). Since this is not an outright 2 pole switch I was wondering if anyone has a good idea on how to run the connection to the usb-6009 for mux. As you know, its got gnd, +-AIO and digital connections.
I have some ideas not sure if it will do as needed.
(2,323 Views)
Not clear to me what you want to do....
Using a Digital output device to control a rs232 4->1 switch/mux?
Why?
Can't you just use the ordinary way with 4 RS232 ports ?
One card or one USB device with four ports or four USB to RS232 adaptors, seems cheaper that the cheapest dig out dev. ,needs no confusing programing/switching ....
Greetings from Germany
Henrik
LV since v3.1
(2,288 Views)
