03-28-2008 05:54 PM
Solved! Go to Solution.
03-28-2008 06:17 PM
Hi Rob,
which dialog did you use? Is this a custom one?
Mike
03-28-2008 07:42 PM
Some possibilities
03-28-2008 08:22 PM - edited 03-28-2008 08:23 PM
03-31-2008 01:31 PM
altenbach, your suggestions seemed to work.
For the custom dialog I have, the trick was also to modify the window properties (in VI properties) by unchecking "show front panel when called" so that the VI would be called without any window appearing until I managed to initialize the controls. Then, I call the FP.close method when done, since the dialog no longer closes automatically.
Rob
