How to hide extra button in NXG Style path controls?
Hi all,
Here's what I hope is a dumb and simple question. I'm starting a new project and using NXG Style controls for the first time, and am struggling with these dumb little "Valid Path"/"Not a Path" buttons on the path control and indicator (see image below). I don't see an option to enable/disable them in the properties dialog box or anywhere else.
How do you hide these buttons?
It looks like, by customizing the control, I can make the box tiny and hide it under the text field, but is that really THE way to do it?
Message 1 of 11
(4,417 Views)
Curiously, you can make it any color you want (left) (FG/BG) but if you pick transparent (right), it shows again. :(.
Message 2 of 11
(4,408 Views)
@MegaHertz wrote:
Hi all,
Here's what I hope is a dumb and simple question. I'm starting a new project and using NXG Style controls for the first time, and am struggling with these dumb little "Valid Path"/"Not a Path" buttons on the path control and indicator (see image below). I don't see an option to enable/disable them in the properties dialog box or anywehre else.
There is another way, but it's no better: When customizing, color it transparent (there are actually 2 pieces to it, color them both transparent).
Message 3 of 11
(4,398 Views)
As altenbach already pointed out (and I neglected to note in my original post), those buttons don't respond to being set to transparent.
Message 4 of 11
(4,351 Views)
I forgot to mention to switch to "customize mode" when customizing.  Then you can make it transparent.  See attachment.
Message 5 of 11
(4,336 Views)
Accepted by MegaHertz
Easiest solution? Use the System path control. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 11
(4,294 Views)
I am not a fan of the NXG style controls.
Another poor work-around would be to drop something over top of it...
(colored for visibility)
Former Certified LabVIEW Developer (CLD)
Message 7 of 11
(4,287 Views)
I believe that (most of) the NXG controls are a step up from the (awful) silver controls.  I'm guessing they exist mostly so you can make consistent GUI across both NXG and Classic.
What would you use that path/not path button for, anyway?
Bill
CLD
(Mid-Level minion.)
Message 8 of 11
(4,278 Views)
oops duplicate.
Bill
CLD
(Mid-Level minion.)
Message 9 of 11
(4,275 Views)
While it doesn't answer the original question (seriously, how is there not a property setting to just hide those buttons?), I think this is the best solution to my issue.
The System path looks exactly like the NXG one (at least in Windows 10), but without those pesky buttons AND with a browse button that actually looks like a browse button.
Thanks for the suggestion!
Message 10 of 11
(4,264 Views)
