How to highlight All text in Control / Indicator?
I need a  VI, that pressing a button I could select all text in control or indicator to be able to copy it then by pressing CTRL + C.
 I tried playing with Property node with select-start, select-end, but no results.
Also didn't find any documentation or examples on how to highlight text in indicator.
Could anyone help with this?
Any advice/tip much appreciated.
Thanks in advance.
(6,412 Views)
Accepted by ACiDuser
The help for 'Selection' mentions that you need to set Key Focus to the control first.
Also there is a system method to copy a string to the system clipboard.
Ton
My LabVIEW Ideas
(6,403 Views)
Thank you! And writing directly into clipboard is even better, thanks to your tip I found where it is!
(6,399 Views)
