How to highlight All text in Control / Indicator?
I need a  VI, that pressing a button I could select all text in control or indicator to be able to copy it then by pressing CTRL + C.
 I tried playing with Property node with select-start, select-end, but no results.
Also didn't find any documentation or examples on how to highlight text in indicator.
Could anyone help with this?
Any advice/tip much appreciated.
Thanks in advance.
(7,053 Views)
Accepted by topic author ACiDuser
The help for 'Selection' mentions that you need to set Key Focus to the control first.
Also there is a system method to copy a string to the system clipboard.
Ton
My LabVIEW Ideas
(7,044 Views)
Thank you! And writing directly into clipboard is even better, thanks to your tip I found where it is!
(7,040 Views)
