How to highlight a line in a text stream and position the cursor at the end.
I would like to select a line in a text control data stream, highlight the text, and place the cursor at the end of the line so that the text control can be edited at that point.
(2,709 Views)
Depends on what you mean by "highlight". If you mean highlight in the sense of when you use the mouse to select text, then you can't do that and then place the cursor at the end, since that would effectively "unhighlight" the text. You need to use a different kind of "highlight", like turning the text bold or something. This KB article talks about highlighting particular characters: How Do I Highlight Particular Characters in a String Control?
See attached for simple example. Modify as needed.
(2,698 Views)
Thanks,  this did the trick!
(2,680 Views)
