How to highlight cell in a tree programatically when mouse arrow is moved over it
Hi
   I would like to highlight a particular cell in a tree when a mouse arrow is moved over it. Similar to wndows drop down menu. Can anybody help me on these.
Regards
Bharath
(3,369 Views)
Accepted by topic author visuman
Jim
(3,356 Views)
Thanks it working !
(3,332 Views)
But I find an issue with this. When there are items with same values in the tree, it always points to the first matched value (even if I set the active item tag to the one where I want to point to). For example, if I have  a tree with values "Hello, Hi, Bye, Hello" and then I set the value to "Hello", it points to the first "Hello" even if I set the tag to the second yellow. Do you know any easy work around for this? Thank you!
@jcarmody wrote:
(3,278 Views)
