How to hold the value from the case struture
Hellow,
I am building a programme, in which I applied a case structure. About every 2-3 seconds its status will turns into "true", and there will be a value output. My problem is: how to keep this output value unchanged (hold that value) when the status turns back to"false"? and then change again when next true status come?
Its kind of ergent, hope someone could help. Thanks a lot!
P.S. The progrmme is build using Control and Simulation tooltik (ie in the control and simulation loop)
Best Regards,
Floyd
(3,835 Views)
Post a VI or a portion of the VI image so we can better help. Thanks! 🙂
TailOfGon
Certified LabVIEW Architect 2013
(3,829 Views)
What are you doing with the "value"?
If it is just an indicator, place the indicator inside the case structure so it only updates in one of the cases.
If you need the updated wire value elsewhere, keep it in a shift register between iterations and wire it across in the FALSE case.
(3,824 Views)
My first thought was shift register.  As Altenbach stated, the False case just passes the value straight through.
(3,820 Views)
another example, the "false" case statement has an indicator...shift reg.png
(3,802 Views)
Wouldn't it be easier to use a Feedback node instead of a shif register? It's basically the same thing as far as I understand.
Cheers, L
(3,718 Views)
Cheers, L
Easier?  Not really.  It kind of depends on the situation.  In general, the shift register is easier to understand.
(3,712 Views)
