remove label text border around control
How do you remove the border around the text label of a control?
Thanks..
(8,720 Views)
If you talking about the Block Diagram - Tools>options>Block Diagrams> (Check) Use Transperant free labels.
(8,716 Views)
Too Slow typing!
I'm not sure exactly what you mean when you say the border of a control. If you are talking on the diagram side, there is an option to place controls with transparent labels. For those that have been already created you can set their background and borders using the paint brush tool "View:Tools Palette"
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(8,714 Views)
Some the text labels I have for some controls have a border around the text. I would like to remove the border if possible.
Thanks.
(8,698 Views)
Accepted by topic author QRP
Go to Tools Palette and select paint and make the labels Transperant once done for one label you can just click the other labels to make it transperant.
(8,693 Views)
