remove label text border around control
How do you remove the border around the text label of a control?
Thanks..
(9,282 Views)
If you talking about the Block Diagram - Tools>options>Block Diagrams> (Check) Use Transperant free labels.
(9,278 Views)
Too Slow typing!
I'm not sure exactly what you mean when you say the border of a control. If you are talking on the diagram side, there is an option to place controls with transparent labels. For those that have been already created you can set their background and borders using the paint brush tool "View:Tools Palette"
Putnam
Certified LabVIEW Developer
LabVIEW Champion
(9,276 Views)
Some the text labels I have for some controls have a border around the text. I would like to remove the border if possible.
Thanks.
(9,260 Views)
Accepted by QRP
Go to Tools Palette and select paint and make the labels Transperant once done for one label you can just click the other labels to make it transperant.
(9,255 Views)
