How to i read multiple text files one bye one
hi all
I need to select the text files multiple times and read files one by one
some how i managed to select the one text file and scan the data in the text file
i need to do this for mutiple files at the same time
Message 1 of 18
(8,925 Views)
If you know how to process one file, take that VI, put it inside a loop and pass in an array of file paths.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 18
(8,917 Views)
Post your work so far. We will take it from that point...
Mathan
Message 3 of 18
(8,905 Views)
To be more exact, use a FOR loop with autoindexing turned on for you array of files.
Message 4 of 18
(8,902 Views)
Great!! You managed to read one file.. Now the same code you might need to repeat in a For loop... Well everyone is suggesting the same and that's the only way (for repetitive work, it needs to be done in a loop).
You also need the array of file paths, and very importantly you need to learn the concept of Auto Indexing.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 5 of 18
(8,893 Views)
.. this is program for pinging the systems
Message 6 of 18
(8,876 Views)
Can u attach your VI?  That image is to small to see anything....
Message 7 of 18
(8,870 Views)
Post your vi instead of an image.
Mathan
Message 8 of 18
(8,869 Views)
i sucessfully reading one text file through this VI
but as like this .. i need for multiple files
also shld read the text line by line
please help me frnds...
Message 9 of 18
(8,842 Views)
Accepted by topic author gowthamggk
Why are you not using For loop???
Use FOR loop for reading multiple files
You can right click the 'Read from Text File' function and select 'Read Lines'. Refer to below code snippet.
Read lines from text file_Code
Message 10 of 18
(8,831 Views)
