Cyclic Numerical Value
I am new to LabVIEW, so there might be a supereasy way to do this, but I can't find it anywhere. I'm trying to make a number go up to 20, then down to 0, then up to 20 again and so on. So I need it to cycle. I was able to do it from 0 to 20 using the Increment function, but from 20 to 0 proves to be more difficult. I know where the problem is: there is no feedback loop in the substraction while loop, so it only does it once. However, I don't know how to implement a feedback loop there.
Is there a way to use variables, like in any text-based programming languages, like C? I've tried messing around with global and local variables but I can't get them to work either.
Please help! Thanks 🙂
(3,671 Views)
(3,656 Views)
UpDown in one loop:
THINK DATAFLOW! In LabVIEW the wire is the variable…
(3,647 Views)
(3,645 Views)
